18 Jan 2024 02:21 PM
Hello.
I am unable to slide open my sky tv glass remote control to change the battries.
As anyone else had trouble opening up their sky tv glass remote control?
And any tips pls?
18 Jan 2024 04:45 PM
Are the batteries definitely dead or could the remote be faulty? I had one which flashed up the low battery warning on-screen for over 6 months with fresh batteries in it so you can take it with a pinch of salt.
Also, try giving the remote a firm twist as if you were wringing out a cloth - this can sometimes bring it back to life.
18 Jan 2024 04:11 PM - last edited: 18 Jan 2024 04:13 PM
Posted by a Superuser, not a Sky employee. Find out moreHi @Jaqi
They back can be very stiff at first. Try lying the remote face down on a cushion or face down in your hand, with the two dots closest to you, and push the back away from you.
MikeAlanR
18 Jan 2024 06:58 PM
Thank you all for your responses.
I managed to slide the cover open with much difficulty but all ok for now.
18 Jan 2024 07:00 PM
Thanks.
@mikealanr wrote:Hi @Jaqi
MikeAlanR
MikeAlanR
16 Jul 2024 05:01 PM
I have found an easy way to open the remote .......
Take 2 large lumps of Blu-Tak.
Hold one on the front and one on the back.
Push in the direction shown by the arrow.. Simples. 😀👍
17 Jul 2024 04:42 AM
Posted by a Superuser, not a Sky employee. Find out more@RolandRat Another method often mentioned on the forum and possibly easier is to use rubber kitchen gloves 😀
18 Aug 2024 01:57 PM
Finding it impossible to open the glass remote , tried all suggestions.
18 Aug 2024 02:00 PM
Tried one more time and surprisingly it opened ., They need to design this remote better , not good for people with arthritis in their hands .
09 Oct 2024 01:36 PM
It is an utterly ridiculous design that is completely unnecessarily difficult to open in my opinion. I have been trying over 15 minutes now and still hasn't opened. Not impressed at all sky!
09 Oct 2024 01:49 PM
Posted by a Superuser, not a Sky employee. Find out moreHi @KMorley76 and welcome to the forum. Removing the back of the remote can certainly be hard the first couple of times as it it very stiff.
I find holding the remote at both ends with the buttons down and my thumbs on top and then applying pressure and pushing with one thumb and pulling with the other in the direction of the arrow is sufficient to remove the cover. Note the back only moves a few millimetres and can then be lifted off.
A number of people have found that wearing rubber kitchen gloves helps to give more purchase on the plastic components.
This LINK may also be helpful.
09 Oct 2024 06:21 PM - last edited: 09 Oct 2024 06:22 PM
Previous versions tended to fracture at the latch point, which is probably the reason for the change for a sliding design.
