16
This discussion topic has been answered Discussion topic: Unable to open sky glass tv remote control to change batteries
This message was authored by: Jaqi
Hello.
I am unable to slide open my sky tv glass remote control to change the battries.
As anyone else had trouble opening up their sky tv glass remote control?
And any tips pls?
This message was authored by: Jones_The_Cat Answer
Re: Unable to open sky glass tv remote control to change batteries
@Jaqi
Are the batteries definitely dead or could the remote be faulty? I had one which flashed up the low battery warning on-screen for over 6 months with fresh batteries in it so you can take it with a pinch of salt.
Also, try giving the remote a firm twist as if you were wringing out a cloth - this can sometimes bring it back to life.
Hi @Jaqi
They back can be very stiff at first. Try lying the remote face down on a cushion or face down in your hand, with the two dots closest to you, and push the back away from you.
https://www.sky.com/help/articles/remote-control-help-sky-glass#:~:text=Only%20use%20AAA%20alkaline%....
MikeAlanR
@Jaqi
Avatar for Jaqi
Thank you all for your responses.
I managed to slide the cover open with much difficulty but all ok for now.
Avatar for Jaqi
Thanks.
@mikealanr wrote:
Hi @Jaqi
MikeAlanR
@mikealanr wrote:
Hi @Jaqi
MikeAlanR
This message was authored by: RolandRat
I have found an easy way to open the remote .......
Take 2 large lumps of Blu-Tak.
Hold one on the front and one on the back.
Push in the direction shown by the arrow..  Simples. 😀👍
@RolandRat Another method often mentioned on the forum and possibly easier is to use rubber kitchen gloves 😀
This message was authored by: ebonge01
Finding it impossible to open the glass remote , tried all suggestions.
Tried one more time and surprisingly it opened ., They need to design this remote better , not good for people with arthritis in their hands .
This message was authored by: KMorley76
It is an utterly ridiculous design that is completely unnecessarily difficult to open in my opinion. I have been trying over 15 minutes now and still hasn't opened. Not impressed at all sky!
Hi @KMorley76 and welcome to the forum.  Removing the back of the remote can certainly be hard the first couple of times as it it very stiff.
I find holding the remote at both ends with the buttons down and my thumbs on top and then applying pressure and pushing with one thumb and pulling with the other in the direction of the arrow is sufficient to remove the cover. Note the back only moves a few millimetres and can then be lifted off.
A number of people have found that wearing rubber kitchen gloves helps to give more purchase on the plastic components.
This LINK may also be helpful.
Previous versions tended to fracture at the latch point, which is probably the reason for the change for a sliding design.
This message was authored by: Teapot2
Guys, just get a flat headed screwdriver and wedge it open. Whoever designed the remote hasn't used one I guess...
That will work, but it's bound to damage the plastic. Last resort, perhaps.
Absolutely Mark! But after about 30 minutes trying to open the remote, and then coming to the forum to see others have similar frustration with the remote, maybe a few remote damages and return to sky might show them the design is not working. I don't have to be a body builder in order to open a remote
Answered - Go to Answer
