Discussion topic: The remote for sky glass is not working
This message was authored by richborough This message was authored by: richborough
Please send a new remote control for sky glass
This message was authored by Laing1 This message was authored by: Laing1
Re: The remote for sky glass is not working
@richborough Afraid you are not contacting Sky's customer services on here, this is a customer to customer forum where customers help each other.
You can contact Sky by phone by dialling 150 if Sky is your phone provider or by following the link below
https://www.sky.com/help/home
scroll down to need more help click on this and you will find a phone number. If you are in ROI please change the flag at the bottom right to the ROI flag
This message was authored by MarkGoldsmith This message was authored by: MarkGoldsmith
@richborough For remote issues read and try the following:
Check the batteries
An easy way to check is to cover the buttons slightly on your Sky remote with your hand. You should see a white backlight behind the buttons. If you don't see the backlight the issue is the power with the remote, so potentially a battery issue.
Check the battery compartment to make sure the paper used to protect the battery has been fully removed. It might have ripped when being removed leaving some behind.
Still can't see the backlight? It’s likely you need to replace the two AAA batteries.
Pair the remote
Press 7 and 9 together on your Sky remote for three seconds (This resets/clears the remote)
Press 1 and 3 together for three seconds (bluetooth mode) and follow any on-screen instructions.
The next option sounds insane but a number of users have reported it resolving the issue with their remotes. You could try holding the remote at both ends and giving it a gentle twist as though you were wringing out a towel. It
If it is still not working have a look at the following guides:
https://www.sky.com/help/articles/remote-control-help-sky-glass
https://www.sky.com/help/home/sky-tv/sky-tv-glass/fixing-a-problem-sky-glass/fixing-sky-glass-remote...
If none of these options work you can request a replacement remote via this link: https://www.sky.com/help/forms/streaming-tv-remote
If you have an old Sky Q remote, you can use that as an interim solution whilst you await the new remote.
Sky Stream and Sky Broadband customer
This message was authored by Exiled-in-HH This message was authored by: Exiled-in-HH
@richborough some.community guidance...
https://helpforum.sky.com/t5/About-Sky-Community/ct-p/Members
