21 Jun 2023 09:28 PM
How do I get a replacement remote control as the battery's supplied with it have leaked and it won't work.
replacement remote £29 on Amazon. Too much!!! And not my fault it's faulty
21 Jun 2023 11:00 PM
@Hazbeau wrote:How do I get a replacement remote control as the battery's supplied with it have leaked and it won't work.
Ring Sky in the morning. They'll sort out a replacement.
21 Jun 2023 11:02 PM - last edited: 21 Jun 2023 11:02 PM
Posted by a Superuser, not a Sky employee. Find out moreHi @Hazbeau
use the link below and skip forward to the last page and then select 'No, I still need help'
https://www.sky.com/help/articles/remote-control-help-sky-glass
Thanks,
Tim
22 Jun 2023 05:19 AM
Thank you
23 Jun 2023 01:09 AM
Posted by a Superuser, not a Sky employee. Find out moreIf you have one available, you can use a Sky Q remote to control your Glass TV whilst you wait for the replacement from Sky..
23 Jun 2023 05:17 AM
Thank you. That's good to know.
23 Jun 2023 05:47 AM
Thank you. All sorted they are sending out a new one 👍
