Discussion topic: Technical fault
This message was authored by: DjPete
Message posted on 02 Jul 2025 01:43 PM
Technical fault
Apparently there is a technical fault and I need to try later, but the service checker says everytning is working fine ?
Message posted on 02 Jul 2025 01:59 PM
Re: Technical fault
@DjPete Usually a quick unplug will solve these kind of issues.
This message was authored by: Spmox1987
Message posted on 02 Jul 2025 02:13 PM
Re: Technical fault
I have tried the unplug and still not able to access the Normal TV channels. Also reset the modem. Anyone else manage to get back on the normal channels?
Message posted on 02 Jul 2025 02:42 PM
Re: Technical fault
@DjPete How are you connecting? WiFi or Ethernet?
With Glass (and Stream) it's better to use Ethernet as it's more reliable and stable than WiFi. If using Ethernet make sure WiFi is turned off in Settings.
It's also worth ensuring Network Standby Mode is set to On.
