Discussion topic: Technical fault on sky sports code DUG 1 id 3c736e - 30th October 2024
Message posted on 30 Oct 2024 09:21 PM
Re: Technical fault on sky sports code DUG 1 id 3c736e - 30th October 2024
I restarted my sky glass and the factory reset my sky glass still same error.
Message posted on
30 Oct 2024
09:22 PM
- last edited:
30 Oct 2024
10:21 PM
by
Chloe-W22
Same here code DUG1 9a9182 [removed] Shocking from sky once again. They aren't on sky go either.
Moderator note: removed swearing
Message posted on 30 Oct 2024 09:22 PM
Re: Technical issue sky sports
Mine still not working 🙄
Message posted on 30 Oct 2024 09:23 PM
Mine works through channel 401
Message posted on 30 Oct 2024 09:24 PM
Same as me after many retries
Not working here either, if it's not the App buffering, or WiFi dropping out, it's this issue
I'm done with Sky
Message posted on 30 Oct 2024 09:25 PM
Go to the game through the Sky Sports app that worked for me
Message posted on 30 Oct 2024 09:26 PM
This was the only solution that worked for me. Thank you! 20 mins missed of the match but glad to at least have the last 15!
Not great Sky, we pay a lot for the service you offer. Not delivered tonight.
Message posted on 30 Oct 2024 09:27 PM
Has just come back on after missing most of the 2nd half. Poor service. 🙄
No still a problem 9.30 , was looking forward to watching pne v arsenal , thanks for ruining that sky and all for a small fortune
Message posted on 30 Oct 2024 09:28 PM
Seen on a previous reply to go through sky sports app on tv (Q), and that worked for me
Same issue - DUG1.
Seems if it is broken, then it works on nothing.
Message posted on 30 Oct 2024 09:29 PM
Sky sports app not working via sky glass it still shows same error
412 now changed to Man Leic game
Try pressing the red button on channel 401
