Discussion topic: Technical fault on all channels and then returns to menu
Message posted on 16 Apr 2024 08:34 PM
Error code keeps coming up.
internet is fine.
switched off broadband pull all plugs out. Turned back on same message!
Netflix and Prime work fine.
Message posted on 16 Apr 2024 08:44 PM
Re: Technical fault on all channels and then returns to menu
@Steve590 How is the TV connecting to your router, poor wifi speeds tend to be the issue.
On the netflix app in the setting menu the speed test should report what speed is being received by the TV.
Samsung 75" 4K TV, Sky Glass Gen 2 55", Sky Stream, VM 1 Gig Broadband, Sony 7.1 AV Receiver, Technisat MultiSat receiver.
Message posted on 16 Apr 2024 09:05 PM
Connected by Ethernet.
broadband speed is coming up as 2.89Mbps
Message posted on 16 Apr 2024 09:36 PM
That's way to low, you need at 20mbps for HD & 30mbps for UHD
Netflix can use speeds as low as 2mbps with ease which is why it works better than Glass TV channels.
Message posted on 16 Apr 2024 09:41 PM
Totally agree. Had several problems ever since having Sky Glass.
Good news though channels are now back!
