Discussion topic: Technical Fault with Channel
Message posted on 15 Aug 2025 01:30 PM
Hi, I have Sky Glass and I have 1GB internet. TV says excellent WiFi connection and then f I want to watch YouTube or Netflix all works well. Randomly it will stop connecting to tv channels saying there is a technical fault.
All the streaming apps work but the tv channels won't unless I restart?
Any ideas on what is causing this as internet. Is working perfectly fine.
Thanks in advance
Cynthia
Message posted on 15 Aug 2025 02:41 PM
							Re: Technical Fault with Channel
I have the exact same problem... it's been going on for over a week now... it's really really annoying having to reset the TV every time you swap from Netflix etc back to normal tv
Message posted on 15 Aug 2025 03:46 PM
Best bet would be to log out of any app you are using, rather than going direct to the home screen, before selecting a live channel. The reason being is the app you were using is still open in the background, and this causes issues.
Message posted on 15 Aug 2025 04:06 PM
Thanks for advice I’ll ensure the family exit this way but be I retesting ti see if it is an issue going forward generally .
Message posted on 17 Aug 2025 05:46 PM
I have the same problem so I am going to send it back and go back to sky q I think Sky Glass, is rubbish. Sky q is way better. And I known in 2029 Sky q is going to be shut down. So I will go somewhere else. That will be breaking My record of staying the a Company for 30 plus years.
