Discussion topic: Stv not showing restart programme on sky glass
Message posted on 24 Nov 2025 10:14 AM
Since yesterday the restart on stv is not showing. Done everything including a full reboot to no avail.
Message posted on 24 Nov 2025 05:48 PM
Re: Stv not showing restart programme on sky glass
Same on Sky Stream. Tried reboot. No luck. Doesn't show the option in STV app or Sky Go. Looks like it is a fault or it's been removed!
Message posted on 25 Nov 2025 10:34 AM
No Watch from Start
Message posted on 25 Nov 2025 11:24 AM
Re: No Watch from Start
Hi @Philip+Lee+Tee I see you have already tried rebooting but without success. If you have not already done so try refreshing the apps by going to System > System management > Resets & Updates and then select refresh apps. This can take up to 24 hours to complete but it is done in the background so you can still use your Glass TV as usual. When needed I tend to do it overnight.
Message posted on 25 Nov 2025 01:19 PM
STV restart of programme
Message posted on 25 Nov 2025 06:03 PM
Re: STV restart of programme
Yes. I've noticed that too and tried everything from rebooting to refreshing apps and still nothing. What's going on
Message posted on 25 Nov 2025 08:47 PM
Looks like an issue specific to stv
see below thread
@lettice please merge
Message posted on 29 Nov 2025 11:50 AM
I've tried refreshing the apps and still not working
Message posted on 29 Nov 2025 09:32 PM
Found out via Internet that ITVX works for restart. Checked and works.
Message posted on 29 Nov 2025 09:34 PM
Found out itvX app allows restart. Tested. Success
Message posted on 01 Dec 2025 08:59 PM
Using ITVX does allow to watch from start as mentioned. However it is only half a solution. It does not allow fast forwarding, despite paying for ad skipping. Until around a week ago I was able to watch from start, fast forward and rewind effortlessly when watching STV via the guide
