6
This discussion topic has been answered Discussion topic: Skyglasstv keeps freezing after averts and i keep having to un plug tv and plug onagain
Had my Skyglass tv for a few months now, but it's started to freeze everytme after an advert has finished. Takes 10 minutes of having to un plug and re start, getting fed up now.
This message was authored by: MarkGoldsmith Answer
Re: Skyglasstv keeps freezing after averts and i keep having to un plug tv and plug onagain
@Simon843 as mentioned in the other posts in this thread. There is already another discussion on this which is tracking the issue.
https://helpforum.sky.com/t5/Sky-Stream/Challenge-channel-freezing-after-an-ad-break/m-p/4557400
The issue has been reported to Sky. The linked thread also suggests some workarounds you can do to prevent you from having to reboot when the channel freezes.
Hi @Anonymous
Is this on live channels, on demand or specific apps? The reason I ask is sky has a feature called adsmart which inserts relevant ads, which can sometimes cause issues and ITVX used to have a real issue with this.
Some more info will help the community provide relevant help.
MikeAlanR
This is now being reported elsewhere on the forum for Challenge TV channel: https://helpforum.sky.com/t5/Sky-Stream/Challenge-channel-freezing-after-an-ad-break/m-p/4557400
MikeAlanR
This message was authored by: Shaund1980
Having the same issue for days now and making me want to cancel sky
And only happens after a sky ad strangely
This message was authored by: Simon843
We are having the same issue with challenge tv , when a sky advertises comes on and green appears all over the same and then freeze and can't turn over for 10 minutes.
