Discussion topic: Skyglass will not turn on
This message was authored by: Martyn52
Message posted on 20 Feb 2024 07:28 PM
My sky glass will not turn on to turn it on. I have to unplug it and plug it back in wait 10 or 15 seconds, and then the remote will work
Find out more
Message posted on 20 Feb 2024 10:21 PM
Re: Skyglass will not turn on
Hi @Martyn52
There are some settings that can be changed which may help:
Go into Settings > startup and standby > turn Networked standby mode ON and turn Overnight power saving OFF.
Hope this helps.
MikeAlanR
