29 Apr 2024 03:10 PM
Keeps saying technical fault and waiting to load but doesn't
29 Apr 2024 03:35 PM
We're having this issue also. Cannot watch anything on tv or the apps. Persistent problem for us which is getting beyond frustrating.
29 Apr 2024 06:09 PM
Posted by a Superuser, not a Sky employee. Find out moreSwitch it off at the plug for a prolonged period of time and see if that helps.
if it doesn't it may well be the strength and stability of the internet connection going to the Sky Glass.
You can try rebooting your router along with rebooting the Glass TV as well to see if that helps.
31 May 2024 12:16 PM
On our tv screen states technical issue you are cyrrentky experiencing a limited service
31 May 2024 12:17 PM
I want this fixed now please
31 May 2024 12:18 PM
@Pol6 wrote:I want this fixed now please
Have you tried rebooting your Glass TV? Turn it off at the wall for a minute or two then power it back on and allow it to restart.
31 May 2024 01:25 PM
Try reading the post already in this thread which contain things to try to resolve the issue.
That's the way of fixing the issue as soon as possible.
