6
This discussion topic has been answered Discussion topic: Sky sports main event live. Watching the darts and it keeps freezing and loosing sound. Anyone else
This message was authored by: largelad1
Program keeps freezing and loosing sound. Happened yesterday aswell. Anyone else having the same problem?
This message was authored by: Jporch316 Answer
Re: Sky sports main event live. Watching the darts and it keeps freezing and loosing sound. Anyone e
@largelad1 wrote:
5.93 Mbps
Sky recommend at least 25-30mb for one device.
how fast is the advertised internet connection you have ......
Hi
can you check your internet speed ? You can do this by going into the native Netflix app and then into settings and then select network check
Avatar for largelad1
5.93 Mbps
@largelad1 wrote:
5.93 Mbps
That's your issue then - there is no way the platform will work correctly when the device is only getting 5 Mbps
What broadband speed do you get to your property?
@largelad1 wrote:
5.93 Mbps
@largelad1 wrote:
5.93 Mbps
If you log on to your router you can check the sync speed to the internet😉
Who is your ISP?
This message was authored by: SteveM11
I agree, other Sky sports content is okay. I'd also say the sound quality is poor, it doesn't seem to be in full surround sound... and the announcer is muffled. It's doesn't sound as rich... what's going on?
