Discussion topic: Sky remote
Message posted on 14 Aug 2024 11:33 AM
Sky remote
Hi both of my sky remotes are not working properly I keep put in new batteries then a couple of days later it's asking for new batteries it's the same in both remotes sky glass and hub
Message posted on 14 Aug 2024 11:50 AM
Re: Sky remote
@Wilmamaclean wrote:Hi both of my sky remotes are not working properly I keep put in new batteries then a couple of days later it's asking for new batteries it's the same in both remotes sky glass and hub
The remotes on Glass & Stream aren't great in terms of quality. It sounds like yours are faulty.
Follow the troubleshooting here and if nothing works then there's a link at the end to order replacements which are free if you're within your 2 year warranty period:
