Discussion topic: Sky remote is not responding correctly
Message posted on 14 Jul 2024 05:33 PM
My sky glass remote is not working correctly, when I press a button it does not work as intended, for example when I press 1 it turns the volume up and down. How can I fix this?
Message posted on 14 Jul 2024 09:58 PM
Re: Sky remote is not responding correctly
Hi @Rob2787
Try unpairing and repairing the remote as per the guide here: https://www.sky.com/help/articles/remote-control-help-sky-glass
If that doesn't work it may be a faulty remote. You can request a replacement here (if under warranty): https://www.sky.com/help/forms/streaming-tv-remote
MikeAlanR
Message posted on 15 Jul 2024 10:45 AM
Hi
i managed to unpair the remote but couldn't repair it because I need to hold button 1 and 3 down to connect it , every time I press button 3 it turns the TV off
Message posted on 15 Jul 2024 02:10 PM
Have you repeated unpairing?
