Discussion topic: Sky live not setting up
Message posted on 18 Dec 2023 08:34 PM
Message posted on 18 Dec 2023 08:57 PM - last edited: 18 Dec 2023 08:59 PM
Re: Sky live not setting up
Can't say I had the same bother, it just worked. One thing to try is make sure the hdmi port is in port one, read elsewhere people having issues if not plugged in to HDMI 1. And make sure the USB-C cable is securely plugged in too.
Do you get a red or white light on the camera? Or pop up saying it's downloading software? Also can you see the serial number etc in the Glass settings menu?
Here is the setup guide for reference: https://www.sky.com/help/articles/setting-up-sky-live.
MikeAlanR
Just a quick question, have you put the camera hdim lead, in hdmi 1 port ?
Message posted on 19 Dec 2023 09:03 AM
Also go to settings on the sky glass, system management and see if sky live software version is showing, it should be ch000.037
