Discussion topic: Sky glass won’t power on after power cut
Message posted on 07 Dec 2024 03:58 PM
We had a power cut and now sky glass won't power back on. The socket works and I have tried another working socket. Tried the reset procedure but nothing will get it to power in ie no red light. Anyone else having problems or advice please.
Message posted on 07 Dec 2024 04:42 PM
Re: Sky glass won’t power on after power cut
Try the recovery procedure in this Sky help article.
Try it a few times, if it does not work first time.
Message posted on 07 Dec 2024 05:24 PM
Have you checked the fuse in the plug ?
Message posted on 07 Dec 2024 05:25 PM
Have changed the fuse in the plug ?
