Discussion topic: Sky glass remote
This message was authored by slm26 This message was authored by: slm26
Sky glass remote
Everytime I press the number 3 on my remote my tv turns off and everytime I press number 7 the volume changes. The number 7 is in my parental pin and when I'm trying to do my pin the 7 isn't working it's only changing the volume. I've tried restarting my tv and also repairing my remote but it's still doing the same thing
What can I do?
This message was authored by Duderinogamer This message was authored by: Duderinogamer
Re: Sky glass remote
I had the same issue, it's a known fault with the remote, contact sky they send out a replacement pretty quickly.
This message was authored by MarkGoldsmith This message was authored by: MarkGoldsmith
@slm26
Reset the remote
Press 7 and 9 together on your Sky remote for three seconds (This resets/clears the remote)
Press 1 and 3 together for three seconds (bluetooth mode) and follow any on-screen instructions.
The next option sounds insane but a number of users have reported it resolving the issue with their remotes. You could try holding the remote at both ends and giving it a gentle twist as though you were wringing out a towel. It
If it is still not working have a look at the following guides:
https://www.sky.com/help/articles/remote-control-help-sky-glass
https://www.sky.com/help/home/sky-tv/sky-tv-glass/fixing-a-problem-sky-glass/fixing-sky-glass-remote...
If none of these options work you can request a replacement remote via this link: https://www.sky.com/help/forms/streaming-tv-remote
If you have an old Sky Q remote, you can use that as an interim solution whilst you await the new remote.
Sky Stream user. Former Sky+ HD and Sky Broadband customer
slm26
Thank you for commenting. I have filled out a form for a replacement remote
slm26
Spoiler
I've tried resetting it but it didn't make any difference. Thank you though
