2
This discussion topic has been answered Discussion topic: Sky glass remote
This message was authored by: Copland204
Sky glass remote
Remote won't work properly so can't watch anything I want .second time I've had problem with sky glass now
This message was authored by: MarkGoldsmith Answer
Re: Sky glass remote
Reset the remote
Press 7 and 9 together on your Sky remote for three seconds (This resets/clears the remote)
Press 1 and 3 together for three seconds (bluetooth mode) and follow any on-screen instructions.
The next option sounds insane but a number of users have reported it resolving the issue with their remotes. You could try holding the remote at both ends and giving it a gentle twist as though you were wringing out a towel.
Another thing to try is remove the batteries from the remote for several hours before reinserting them.
If it is still not working have a look at the following guides:
https://www.sky.com/help/articles/remote-control-help-sky-glass
https://www.sky.com/help/home/sky-tv/sky-tv-glass/fixing-a-problem-sky-glass/fixing-sky-glass-remote...
If none of these options work you can request a replacement remote via this link: https://www.sky.com/help/forms/streaming-tv-remote
If you have an old Sky Q remote, you can use that as an interim solution whilst you await the new remote.
Avatar for Copland204
Remote wont function correctly so cant switch channels etc tv useless mow
Reset the remote
