Discussion topic: Sky glass remote not working with new batteries
This message was authored by: Rwilliams3103
My sky glass remote is not working
I have changed the batteries
I have pressed 7+9
Re: Sky glass remote not working with new batteries
@Rwilliams3103  Try pairing the remote again as follows:
  1. Press 7 and 9 together on your Sky remote for three seconds (This resets/clears the remote)
  2. Press 1 and 3 together for three seconds (bluetooth mode).  A connected message should appear on your screen, press continue and it's all done.
If this doesn't help have a look at the following links to some relevant troubleshooting guides
Troubleshooting guide
Remote help
You could also try holding the remote at both ends and giving it a gentle twist as though you were wringing out a cloth.  Even though it sounds an unlikely solution it has got many faulty remotes working again (including my own on 2 occasions).
If none of the above help then I would request a replacement at the following link: Streaming TV replacement remote
If you are lucky enough to have one available you can use a Sky Q remote while you wait for a replacement to arrive.
