Discussion topic: Sky glass remote buttons not working
Message posted on 30 Dec 2024 08:42 PM
Circle button not working. If I click left it turns TV off, up & down not working and right button brings up settings. Home button not working. Voice control, standby and volume work.
Message posted on 30 Dec 2024 09:49 PM
Re: Sky glass remote buttons not working
@SophieB92 Have you tried clearing the remote and then re-pairing it again? This can be done as follows:
- Press 7 and 9 together on your Sky remote for three seconds (This resets/clears the remote)
- Press 4 and 6 together for three seconds
- Press 1 and 3 together for three seconds (bluetooth mode). A connected message should appear on your screen, press continue and it's all done.
If that doesn't help remote troubleshooting guides I have linked below:
You could also try holding the remote at both ends and giving it a gentle twist as though you were wringing out a cloth. Even though it sounds an unlikely solution it has got many faulty remotes working again (including my own).
If none of the above help then I would request a replacement at the following link: Streaming TV replacement remote
Also, if you are lucky enough to have one available you can use a Sky Q remote while you wait for a replacement to arrive.
Message posted on 01 Jan 2025 12:56 AM
I have the exact same issue, it started suddenly on 31/12/24. Repairing and twisting have not worked, any other suggestions?
Message posted on 01 Jan 2025 01:15 AM
Hi @GraemeDug Happy New Year.
If you have also run through the troubleshooting guides mentioned in my post 2 above and it has not fixed the issue then follow the link I provided and request a replacement (you will need to sign into your MySky account).
If you have one available you can use a Sky Q remote while you wait for the replacement to arrive.
Message posted on 01 Jan 2025 07:59 PM
This has just hapened to me, the exact same thing. Tried every solution but need to order a replacement most likely.
Message posted on 26 Feb 2025 09:23 PM
Power off button not working
