Discussion topic: Sky glass red standby light flashing
Message posted on 01 Feb 2024 06:09 PM
Hi my 43 inch sky glass keeps going into a mode where the standby light flashes. I have to keep switching it off to reset it. Is this something I should be worried about. It's happened 5 times in the last week alone. Is it updating or is it a possible fault?
Message posted on 01 Feb 2024 06:13 PM
Re: Sky glass red standby light flashing
@Aaron43 wrote:Hi my 43 inch sky glass keeps going into a mode where the standby light flashes. I have to keep switching it off to reset it. Is this something I should be worried about. It's happened 5 times in the last week alone. Is it updating or is it a possible fault?
If you've had it for less than two years then you should ring Sky for further troubleshooting and request a replacement under warranty if it continues to do this.
