5
This discussion topic has been answered Discussion topic: Sky glass pin
This message was authored by: Anna2409
Sky glass pin
Keep asking for pin when setting up my new tv and won't let me go to the next step I put the pin and only option to change the pin so I did as well but still not accepting keep asking to put pin on
This message was authored by: Jporch316 Answer
Re: Sky glass pin
Initial pin should be the last 4 digits of your mobile phone number that sky have  on their records
Re: Sky glass pin
Avatar for Anna2409
Re: Sky glass pin
Is not working the pin which is correct so I keep changing and is not working so annoying
This message was authored by: Ciara38
Re: Sky glass pin
I am having the same problem....inputting the correct pin and NADA!  Very annoying Sky!
Re: Sky glass pin
The last 4 digits of the registered mobile on your account .... unless you ve changed it
Re: Sky glass pin
Thanks, but that's what I'm putting in and still nothing..
