10 Mar 2023 08:42 AM - last edited: 10 Mar 2023 09:30 AM
That's because 50 on Sony Bravia TV is actually 0 aka neutral
Some TV's sharpness uses -/netrual/+
Some other TV brands 0 is neutral it will vary with different TV's
Example of image that's correct and not
Left: the original image. Right: the edge-enhanced "sharper" version. The "halo effect" is what the sharpness control adds.
The original image on the left is correct and does not have any artificial sharpening
10 Mar 2023 11:01 AM
Interesting points of view. Thankyou.
Also if you prove those updated UHD settings to be better than the ones posted on here the other day please share?
10 Mar 2023 11:04 AM - last edited: 10 Mar 2023 11:06 AM
An alternative setup for uhd users ONLY.
I had some feedback that dark films/horror films were better but could struggle with the settings at the start of this thread.
it's a hard balance to settle accross all the channels and apps, as at one point I'll think yes smashed it with sky movies uhd then go to Netflix atmos and it's horrid.
This is a second option I've had people testing. Some prefer this, some prefer the other. Either way they said both options are better than auto/vivid/cinema etc etc
colour balance management remains 50/50/15 for every colour.
please note you can't use a mix of option 1 at the start of the thread and this option. Because white balance remains the same on both I've had to try and get to a position where they both sit comfortably
10 Mar 2023 11:09 AM
Sorry trimmed a bit off the previous picture
10 Mar 2023 11:15 AM
Somones just advised me to let the channel load a few secs before judging it. He's noticed it will adjust slightly on some channels usually after the 'restart this programme' message comes off
Thanks for sharing..
Unfortunately I'm struggling to read some of those numbers on my phone though.
The resolution (maybe it's my phone) isn't there.
10 Mar 2023 11:20 AM
The colour saturation setting on UHD,is that 80 or 60?
10 Mar 2023 11:21 AM
Uhd
Backlight 25
Auto
Bright
Bright
Uhd
Contrast 55
Sharp 25
Bright 56
Satu 80
Hint 42
White balance
Rgain 225
Ggain 250
Bgain 210
Roff0
Goff 50
Boff 50
Hd
Backlight 45
Auto
Bright
Bright
Uhd
Contrast 50
Sharp 35
Bright 45
Satu 59
Tint 45
White balance
Rgain 225
Ggain 250
Bgain 210
Roff0
Goff 50
Boff 50
10 Mar 2023 11:23 AM
That's excellent help thankyou
10 Mar 2023 12:02 PM
Is the answer in this discussion an answer or a correction to the first post?
10 Mar 2023 01:22 PM - last edited: 10 Mar 2023 03:17 PM
this post is for clarification of what's been discussed and so I can set as the answer due to there being a few comments around clarification and then me suggesting 2 more settings for helping with movies.
click on each image and it should be clearer to zoom in on and view.
I've also said in the screenshots initially that UHD users have 2 choices but what I should have said is both UHD and non UHD have 2 choices. However UHD users need to ensure they use both of either the right ones, or both of the left ones. For example You shouldnt change uhd then not change hd, and you can't use the left one for uhd and right one for hd. Needs to be both left, or both right.
10 Mar 2023 02:00 PM
@Anonymous Ill give these a go this weekend - thanks for sharing.
Do you epxerience problems is dark scenes that i describe here?
https://helpforum.sky.com/t5/Glass-Stream/Local-dimming-lag-fault-or-expected/m-p/4241908#M85900
10 Mar 2023 03:42 PM
@Anonymous
Just did a basic test
Your custom settings for HD not right
It's causing crushing of image details
BBC 1
Notice the clouds in the Sky
Auto Settings you can see the clouds
Your Custom Settings for HD
Notice the clouds details not seen
10 Mar 2023 04:10 PM
@Paul+Boland it could be that programme as I've noticed during the day bbc1 has some shocking quality it outputs and almost look SD. Some examples off top me head are:
- escape to the country
- money for nothing
- bargain hunt (sometimes)
- homes under the hammer
bbc2 can the same too but because I don't trust bbc1 daytime and bbc2 show on at moment looked hd and to me I've done the test on that.
As I say these settings are just suggestions and personal taste. But I personally think the custom looks better below.
10 Mar 2023 04:13 PM
@MrLeeches I haven't had any issues myself. But I saw someone mention it earlier. Try the new set of settings I suggested today off back of 'films being dark', if that doesn't work i: argue with sky that it must be a fault with tv as there's others not having this issue.
