Discussion topic: Sky glass not working
Message posted on 08 Aug 2024 09:02 PM
Keeps saying wait for programme to load then says technical issue
Message posted on 08 Aug 2024 09:05 PM
Re: Sky glass not working
The first thing to try is a reboot if you haven't already.
If your device is on software version QS28:
1. Go to Settings
2. Go to System Management
3. Press Select
4. Go to Resets and Updates
5. Press Select
6. Go to Restart Device
7. Press Select.
Note this will take a few minutes to reboot, so expect to see a blank screen for 2 minutes until the Sky logo appears as its starting up.
If you don't have software version QS28 yet, then to reboot the device you need to turn it off at the plug for 2 minutes.
