Discussion topic: Sky glass not seeing virgin box
Message posted on 13 Apr 2025 04:34 PM
Hi, I'm wondering what I'm doing wrong.
i have a 43" sky glass and i have connected my virgin media box to it via HDMI. I'm confused as to why I can't access sky movies and sky sport as per my subscription with virgin.
Can anyone help?
Message posted on 13 Apr 2025 04:55 PM
Re: Sky glass not seeing virgin box
Have you set the hdmi to old in the settings it might be that !!can i do you have a sky subscription for the tv ? As things like the ultra hd and dolby atmos surround will not work as far as i know as we have to subscribe to them to work on the tv, have you tried plugging your box in hdmi port 3 ?
Message posted on 13 Apr 2025 05:24 PM - last edited: 13 Apr 2025 05:25 PM
Are you looking for movies and sport on the Sky UI or the Virgin UI?
If you subscribe through Virgin you must use the Virgin UI via your HDMI input and using the Virgin remote. If Virgin isn't letting you watch that through their UI then you need to contact Virgin to address that for you.
If you're not able to connect to the HDMI input to see your Virgin UI, try the tip from @peter-marlow+1966
