Discussion topic: Sky glass message waiting for programme to load
This message was authored by Juliebubb This message was authored by: Juliebubb
When I turn tv on or go from streaming to watch something different my programme doesn't load and I have to unplug and plug back in to fix it, happening more frequently and getting really fed up and wish I had never switched to sky glass there is always something not quite right.. this current issue was happening once every few weeks now it has happened twice in one week
This message was authored by Fothergill1 This message was authored by: Fothergill1
Re: Sky glass message waiting for programme to load
@Juliebubb  I don't see this message very often but when I do I switch to another channel for a few seconds and this will often resolve this issue.
If that doesn't work then I restart my puck (Glass in your case). To restart/reboot your Glass TV go to  Settings > System Management > Resets & Updates > Restart device (do not do a factory reset).  It takes about 3 minutes to completely reboot. You will have a blank screen for a couple of minutes before the Sky logo appears so don't panic when you first start the process.
Good luck 🤞
If my post has solved your issue please mark as an "Answer"
This message was authored by Wrcarter This message was authored by: Wrcarter
I've suddenly started having issues when turning on tv
a message saying I need to refresh and needs me to turn off several times
everything appears to be slower
I've reported it but they have no idea how to resolve
Update to my previous response to @Juliebubb
I said I don't often see this problem but I was obviously tempting fate as It just happened to me.  I tried changing the station for a few seconds but this didn't help so I rebooted and the issue was resolved (until the next time).
This message was authored by Wayne1270 This message was authored by: Wayne1270
What I've realised since having Glass for 2 years is Sky are not equipped to deal with complaints and technical issues.
i was told they don't have engineers and all they advise is basic trouble shooting. I was told there are no known issues but this forum would suggest otherwise .
for months I've had to repeat myself send photos in and battle with some poor attitudes. On one occasion they blamed my tv and said as it's out of warranty it's my issue.
My advice is just think hard before taking out this service as I've had constant issues since day 1. They also blame my internet provider but I have 1GB speed and no issues.
no doubt mine will go to an ombudsman
Juliebubb
An update on this one, it is happening abput once month, I know when it is going to happen because when I first turn tv on, the sound from my previously streamed show is playing in the background when normally it is silent when it turns on.... anyway the answer of turn it off at the wall and turn back on seems to fix the issue but very annoying and doesn't really fix it for good...
This message was authored by Jporch316 This message was authored by: Jporch316
I've started getting the issue where the previous stream sound is still playing when I turn on glass. It's mostly paramount plus and potentially one of the kids is not exiting the app properly before turning the tv off.........
43inch and 55 inch Sky Glass & sky live camera 3 Pucks on virgin media M350 hub 5x. 4 x sky mobile sims.
Juliebubb
I have resorted to exiting the app properly and watching another live show before turning off and it still happens xx
Yes me too ...  I've tried everything but my internet provider BRSK warned me about keep resetting router
it's the attitude of sky saying " no known issues" which annoys me
Juliebubb
I have the fastest Internet in can through sky so i would like to think if isn't that causing the issue, just the tv xxx
