Discussion topic: Sky glass issues
Message posted on 24 Jun 2024 04:53 PM
Sky glass issues
Tv is randomly switching on and off and remote control is non responsive
Message posted on 25 Jun 2024 08:18 AM
Re: Sky glass issues
@Shuggy791dollartreecompass wrote:Tv is randomly switching on and off and remote control is non responsive
Hello, @Shuggy791dollartreecompass
TV randomly switches on and off and the remote control doesn’t respond, there are a few troubleshooting steps you can try:
Check Remote Batteries:
Weak or depleted batteries can cause remote control issues.
Open the battery compartment, ensure correct polarity, and replace with fresh batteries.
Clear Obstructions:
Objects blocking the infrared signal can affect remote functionality.
Remove any obstacles between the remote and the TV sensor.
Clean the Sensor:
Dirt or debris on the sensor can cause problems.
Use a soft cloth or cotton swab to clean it.
Re-Pair the Remote:
Follow the user manual instructions to re-pair the remote with the TV.
Power Cycle the TV:
Unplug the TV from the wall socket for 5 minutes.
Plug it back in and test if the remote works.
I hope this step is helpful to you.
Best Regard,
Gregory Chavez
