Discussion topic: Sky glass has no sound and some programmes not loading
This message was authored by: Miky1
My sky tv just stopped working yesterday morning no sound and most channels won't load I've tried all the reset process and still no joy can anyone help please
This message was authored by: Jporch316
Re: Sky glass has no sound and some programmes not loading
Can you get into the Netflix app and go to the settings and select network check .... this will tell you the speed your glass is getting . It may also be worth a  full reboot of your router.
This message was authored by: Andy3394
Having same issue did u get it sorted
Help
Sky glass not working no sound factory rest turned off router everything iv no sound and some channels not loading
Avatar for Miky1
Still not working did you sort yours
This message was authored by: AP2324
I have tried watching some programmes on Sky Atlantic today - sometimes the sound will play, but never the picture.
Everything else is working fine. It was only delivered yesterday and problems already!!
Went to bed turned it off for few hours it seems fine now I think these Internet based tvs need a break now and then I have it on most of the day think it over loaded hope this helps if not contact sky we pay enough so frustrating
