Discussion topic: Sky glass gen 2 wall mount plate
This message was authored by AndyT2021 This message was authored by: AndyT2021
Hi there just received my sky glass gen 2. I wasn't made aware I needed to buy additional plate for wall mount as last one came with box. How can I get one sorted?
This message was authored by SKY1992bf This message was authored by: SKY1992bf
Re: Sky glass gen 2 wall mount plate
@AndyT2021  The only way currently to do this is to cancel the order return and reorder this time including the wall mount in the order
Please note: I am just a sky customer not a employee - posts from sky employees are clearly marked as such
This message was authored by Carnoch04 This message was authored by: Carnoch04
I am sure I read somewhere on here that a generic mount will fit the Gen 2 but I ,may be mistaken.
Sky Stream since launch with Philips 55" Mini LED. Sky Glass Gen 2 55" now added.
This message was authored by Skull+Treaty This message was authored by: Skull+Treaty
@Carnoch04
Its mentioned in this post
"Sometimes, the only choices you have are bad ones, but you still have to choose"
@Skull+Treaty Thanks!
