3
This discussion topic has been answered Discussion topic: Sky glass gen 2 stuck light flashing red & white
This message was authored by: fifik69
Tv was freezing on channels so I unplugged tv , plugged back in then got grey screen updating tv but continually goes back to the start
Avatar for fifik69
This message was authored by: fifik69 Answer
Re: Sky glass gen 2 stuck light flashing red & white
Thank you for your reply I tried for an hour but nothing work rang sky they are sending a replacement tv, but I left it unplugged all night tried it this morning working fine now 🤷‍♀️
Avatar for fifik69
And the light just flashes red & white
Hi @fifik69
Sounds like something's gone wrong with the firmware. You will need to follow all the steps outlined in this article:
https://www.sky.com/help/articles/setting-up-sky-glass-sky-logo
Particularly step 5 the recovery process. You may need to attempt this a couple of times to get it to work. If it doesn't you will need to speak to Sky and get your set replaced under warranty.
MikeAlanR
Avatar for fifik69
