Discussion topic: Sky glass gen 2 stand stuck
Message posted on 17 Mar 2025 06:59 PM
I want to put sky glass 2nd gen on the wall and we cannot remove the base stand
it appears to be stuck in
can anyone help??
Message posted on 17 Mar 2025 07:04 PM
Re: Sky glass gen 2 stand stuck
There are some clips underneath I think that you need to use to unclip it. I had to return my first Glass 2 TV due to a panel fault and the delivery guys just turned it upside down on my sofa and removed the stand that way. If the stand won't unclip then it may have been assembled incorrectly upon delivery.
If you still can't do it I would ring Sky to see what they say.
Message posted on 18 Mar 2025 09:51 AM
I stood mine up on the floor, stood on the panel and pulled the TV up and it worked.
