27 Oct 2024 10:19 PM
Why can't I watch my mini box with sky glass
27 Oct 2024 10:44 PM
It's not possible to have a subscription for both systems, but a subscription Q Mini should output to a non-subscription Glass television.
27 Oct 2024 10:47 PM
It's saying I can't connect to the mini box without main sky q box which is now disconnected as using sky glass as main tv
Posted by a Superuser, not a Sky employee. Find out moreHi @Rowen25
If you mean Sky Q mini box. These talk to the Sky Q main box and get signals from satellite connection. Sly Glass recieves it's signal from your broadband connection. When you take Sky Glass your Q contract is terminated and all Q boxes need returning to Sky as they are loaned to you.
You can take out whole home subscription and order a Sky Stream Puck for your second TV. However unlike a Q mini box it talks directly to the internet and not to Glass.
If you mean you have a puck and glass, it could be you don't have whole home? Or broadband speeds are too low. You need 25Mbps for HD and 30Mbps for UHD for each Glass / Puck device.
If you post further information we will do our best to answer if the above doesn't cover it.
MikeAlanR
27 Oct 2024 10:50 PM
So I need to order pucks from sky for multi room ?
27 Oct 2024 10:56 PM
@Rowen25 wrote:So I need to order pucks from sky for multi room ?
Yes. And add the Whole Home subscription to your package.
Yes. See the section "Watching Sky around the home" here: https://www.sky.com/help/articles/sky-glass-faqs
But Sky Q and Glass/Stream are different systems and don't work together and you will need to return all your Q kit.
MikeAlanR
28 Oct 2024 07:36 AM
28 Oct 2024 08:24 AM
That's why I said you needed a subscription Mini, which would necessitate a main Q box.
