Discussion topic: Sky glass and other tv
This message was authored by My+boys This message was authored by: My+boys
I have a tv connected to a Sky multiscreen box and another tv using a mini box. I want to set up another tv - can I get a Sky glass? Will that mean I then have to get 'pucks' for the other tvs and disconnect the multi box and mini box?
really want the easiest and cheapest solution.
thanks
Re: Sky glass and other tv
@My+boys  You don't need to get a Glass TV, you can just get stream pucks for all the existing TV's
Please be aware they are very different to Sky+ or Sky Q setups and you need good broadband speeds for each puck you use.
See the FAQ's here which should answer most questuions https://www.sky.com/help/home/sky-tv/sky-tv-stream/buying-sky-stream/sky-stream-faqs/articles/sky-st...
This message was authored by MarkGoldsmith This message was authored by: MarkGoldsmith
If you are used to Sky Q and like recording content and keeping it for as long a you want then I'd suggest sticking with Sky Q.
Via streaming you can only access content that is available on the on-demand/catch up apps for as long as it's available. A number of users recently got hit by the removal of content from paramount plus whilst they were in the middle of watching a show. Also you may need subscriptions to some services like Disney + to watch shows on demand that you previously may have just recorded via a linear channel, as that channel may not have the on-demand rights via their catch up app.
Sky Stream user. Former Sky+ HD and Sky Broadband customer
NOT a Sky Employee
