Discussion topic: Sky glass air 65’
Message posted on 08 Jul 2025 10:51 PM
Sky glass air 65’
Just wondering if anyone knows if the TV should come with a bracket ? I've received and set it up on the stand for the time being as I've not seen a bracket anywhere in the packaging. I don't want the swivel one so don't see the point in purchasing one for £20 a month .
Message posted on 08 Jul 2025 11:36 PM - last edited: 08 Jul 2025 11:46 PM
Re: Sky glass air 65’
Hi @Matthew871 You don't mention which Glass TV you have. The wall mounting bracket for the original Glass TV is an integral part of the stand. The instructions can be found at THIS link.
The Sky Glass Gen 2 does not have a wall mounting bracket included and must be purchased at the same time as the Glass TV if you want a Sky bracket, however standard VESA mounts are compatible. The wall mounting guide for the Gen 2 is also included in the link I provided above.
I believe the Sky Glass Air doesn't come with a wall mounting unit either but is compatible with universal wall mounting VESA brackets.
