Discussion topic: Sky class no power
Message posted on 07 Aug 2024 04:08 PM
Sky class no power
Sky glass TV had it for four hours no power not turning on whatsoever now. when first initially set up came on for the first time to set up my broadband once it was on and then powered down could not get the TV to switch back on spoken to the guys at Liverpool one at the shop gave me some advice still not working.
Message posted on 07 Aug 2024 04:18 PM
Re: Sky class no power
Repeat this again, no power on sky Glass TV
Message posted on 07 Aug 2024 04:27 PM
@Tricia13212 wrote:Repeat this again, no power on sky Glass TV
If you've tried turning it off at the wall for a minute then powering it back on and there's still nothing happening then you'll need to ring Sky for further troubleshooting and potential replacement (if you are within the 2 year warranty period.)
Message posted on 07 Aug 2024 05:38 PM
Hi @Tricia13212
As @Mister_Dalek has pointed out this is a customer helps customer forum. We are fellow subscribers! Sky have a help article relating to this issue. Try following ALL the steps here: https://www.sky.com/help/articles/power-issue-help-sky-glass#:~:text=Try%20the%20recovery%20process.....
If that doesn't work, you will need to speak to Sky customer services.
MikeAlanR
Message posted on 07 Aug 2024 06:07 PM
Have you checked mains cable is fully in socket? Try with another cable in case problem with cable/plug.
Sky Ultimate and whole home, Diamond VIP User
BT Hybrid FTTC, BT Smart Hub 2 + 1 disc
