This discussion topic has been answered Discussion topic: Sky TV Wall Mounting
Message posted on ‎14 Mar 2024 12:11 PM
Followed the instructions for wall mounting Sky Glass. We have then hung the TV on the bracket but there are no further instructions. Is it meant to just hang? It's probably right but it just feels like it needs to be bolted or secured but there's no access to do so as it's almost flush to the wall.
Message posted on ‎14 Mar 2024 02:10 PM
The set is secured by the lugs on the top edge of the bracket: to be dislodged it would have to be both lifted and tilted backwards, which is incredibly unlikely to happen accidentally.
Message posted on ‎08 Feb 2023 09:19 PM
How do I put a sky glass on a wall, no fittings etc
Message posted on ‎08 Feb 2023 09:23 PM - last edited: ‎08 Feb 2023 09:28 PM
Re: How do I put a sky glass on a wall, no fittings etc
Hi @Kayzoo123
The wall mount is included in the package along with spacers.
You need to source your own screws to attach the mount to wall.
https://www.sky.com/help/articles/sky-glass-wall-mounting-guide
Thanks,
Tim
Message posted on ‎08 Feb 2023 09:28 PM
I don't have that, people from sky come and set it up to go on TV unit but took the packing away?
Message posted on ‎08 Feb 2023 09:30 PM - last edited: ‎08 Feb 2023 09:32 PM
Hi @Kayzoo123
They should have left you the 4 spacers. The wall mount is actually what attaches the TV to stand, when using it to attach to the wall you dismantle the stand.
Thanks,
Tim
Message posted on ‎09 Feb 2023 07:02 AM
@Kayzoo123 alternstively you can buy a thrird party wall mount. Glass TV have standard mounting points in a 300 x 200 arrangement.
Message posted on ‎14 Mar 2024 12:48 PM
Re: Sky TV Wall Mounting
@Frieslick wrote:Followed the instructions for wall mounting Sky Glass. We have then hung the TV on the bracket but there are no further instructions. Is it meant to just hang? It's probably right but it just feels like it needs to be bolted or secured but there's no access to do so as it's almost flush to the wall.
As long as you followed the instructions and the wall you attached the bracket to is strong enough then that's it. Glass is a heavy TV so gravity will hold it onto the bracket.
Message posted on ‎19 Apr 2024 04:05 PM
Does sky have people they send to put sky glass on the wall
Message posted on ‎19 Apr 2024 04:15 PM
No, you need to sort that out yourself.
Samsung 75" 4K TV, Sky Glass Gen 2 55", Sky Stream, VM 1 Gig Broadband, Sony 7.1 AV Receiver, Technisat MultiSat receiver.
Message posted on ‎02 Jul 2024 03:19 PM
Can someone recommend a good fit to wall mount my sky glass (65) Also need them to supply the mount as well?
Message posted on ‎18 Jan 2025 06:53 AM
I was going to ask the same question
Message posted on ‎18 Jan 2025 07:01 AM
Thinking of purchasing sky glass
I'm thinking of purchasing sky glass but would like to know if when selecting the fast delivery option where they install and take to room of choice etc does this include wall mounting if I provide the correct bracket,screwdriver etc
Message posted on ‎18 Jan 2025 07:15 AM - last edited: ‎18 Jan 2025 07:26 AM
Re: Thinking of purchasing sky glass
Have moved your other posting here and removed your duplicate posting.
For your question on delivery, setup and mounting;
The delivery, now from AIT, does not offer setup and wall mounting.
You have to do the setup and mounting yourself or arrange for a third party to mount it.
Delivery Sky help article;
Wall mounting Sky help article guides;
Message posted on ‎18 Jan 2025 07:54 AM
Ok thats great to know thank you for your response
