18 Feb 2023 09:46 PM
Hi, I don't have the rubber spacers necessary to put my Sky Glass up on the wall, I'm assuming they went out with the packaging - Will Sky supply some more please?
18 Feb 2023 09:55 PM - last edited: 18 Feb 2023 10:38 PM
You could contact Sky directly to see if they can assist you.
This thread has some dimensions of spacers in case you want to source your own
https://helpforum.sky.com/t5/Glass-Stream/Sky-Glass-Wall-Mount-Spacers/m-p/3834372#M20807
Thanks,
Tim
19 Feb 2023 09:14 AM - last edited: 19 Feb 2023 09:17 AM
Posted by a Superuser, not a Sky employee. Find out moreHard black plastic rather than 'rubber'. Anything providing the same minimum distance from the wall surface should work: they are there to permit the rear of the set to seat correctly over the wallplate.
