Discussion topic: Sky Glass wall mount dimensions
Message posted on 10 May 2025 04:47 PM
Hi, I'm trying to find out the dimensions of the Sky Glass wall mount, as in the width, height and most importantly the depth. We're trying to understand how far the TV will sit away from the wall when it is installed. Can anyone help?
Message posted on 10 May 2025 06:03 PM
Re: Sky Glass wall mount dimensions
@woodpecker1 From Google:
The VESA (Video Electronics Standards Association) spacing for all sizes of Sky Glass and Sky Glass Gen 2 is 300x200mm. This means the distance between the screw holes on the back of the TV for wall mounting is 300mm horizontally and 200mm vertically.
Additional details:
Sky provides wall mounting templates for each size (43", 55", and 65").
You can also find detailed wall mounting instructions and safety information on the Sky website.
The 55" Sky Glass Gen 2 has dimensions of 122.89 x 78.79 x 22 cm (with stand), according to the Sky Community.
The 55" Sky Glass (Gen 1) has dimensions of 123.09 x 78.89 x 24.8 cm (with stand).
You need to be aware that the wall mount can only be ordered at the same time as ordering the Sky Glass Gen Two set. Delivery men will only drop the TV at your door. If you get Premium Delivery they will unpack it and place it onto its stand if required - they will not wall mount though.
Message posted on 10 May 2025 07:18 PM
Thanks for your reply.
I'm trying to understand how much the TV would 'stick out' from the wall if you use the wall mount. I couldn't find this information anywhere. I've seen a YouTube video of an installed TV which appears to be flush to the wall, but I can't see how that is possible (the installation process was not shown in the video).
Message posted on 10 May 2025 07:45 PM
@woodpecker1 Sorry, I don't trust wall mounts for a TV, so mine sits on its stand on a TV cabinet. Much safer!
Message posted on 10 May 2025 08:12 PM
Is this a gen 1 or gen 2 tv you asking about
Message posted on 10 May 2025 08:15 PM
Gen 1 tvs the wall mount is part of the stand and sits flat against the wall I don't know about the gen 2 as you now can buy the wall mount when you order the gen 2 from sky
Message posted on 10 Jun 2025 03:21 PM
I'm getting conflicting views on whether a Gen 2 can sit on the same wall mount from the Gen 1 already in place, any advice please?
Message posted on 11 Jun 2025 07:47 AM
@PW24 .
A Gen2 television cannot mount on a Gen1 wall plate
