5
This discussion topic has been answered Discussion topic: Sky Glass - wall bracket
This message was authored by: Belinda72
I've just ordered sky glass, does anyone know if it comes with wall bracket as standard? I didn't see an option when I was ordering?
This message was authored by: MarkGoldsmith Answer
Re: Sky Glass - wall bracket
The wall bracket isn't included by default and it currently can only be ordered from Sky when you purchase the Sky Glass.
You can use any standard VESA mount but you need to check it supports the weight of the Glass TVs which are quite heavy for their size.
This message was authored by: QT_Pi
No, we've just got Sky Glass and ordered a bracket from Amazon. It is compatible with standard VESA fittings.
@Belinda72
The Gen1 model (2021) came with a bracket, but the Gen2 (2025) does not.
Avatar for Belinda72
Thanks for letting me know
Thanks for replying
