18
This discussion topic has been answered Discussion topic: Sky Glass remote volume mute.
This message was authored by: Hobbayne64
Has anybody noticed that when they push the volume mute on the remote control, it doesn't actually mute the sound anymore? It just reduces it in volume a bit. This is only started happening this morning and anybody had any similar problems.?
This message was authored by: Nobble Answer
Re: Sky Glass remote volume mute.
I have managed to fix this!
I had exactly the same issue, it started a few days ago after I'd connected my bluetooth headphones for the first time?
I was able to fix it by pressing the the three dots button on the remote "..." top left.  Then selected "Audio Output" and clicked on "TV Speakers", which was unticked for some reason, when I think it should be ticked by default?
Now works fine.  Good luck.
(I'm on OS 1.3, Build version: QS033.014.00P.  Remote control firmware: 5103.4.8)
This message was authored by: BrynMeurig
My Glass TV updated to QS033 overnight, and I now have the same problem, and more....
When turning the set on, the first channel I select has no sound until the volume is turned up or down. This can be from the guide, continue watching or the apps (Netflix, Amazon, etc.)
Mute moves the volume graphic to minimum, but the volume stays the same.
Reducing the volume to minimum mutes the sound.
Just to add, restarting the TV or unplugging for 30 minutes made no difference.
Avatar for Hobbayne64
Level 3 icon
Sounds like another update has screwed up the system again. 🙄
This message was authored by: Azgard3
Got the same issue.
@Nobble
Brilliant, that's fixed mine too.
Quite surprising though, as the only Bluetooth device I have connected is the TV remote!
@Hobbayne64 @Azgard3
Can you both try the  fix as mentioned  in post 6?
This message was authored by: Tim114
Ah ha , don't know how u managed it but great Scot , it works now ! I can mute with the mute button .
This message was authored by: grmay
@Nobby6 you legend, sorted mine with your instructions. Thank you
You legend, fixed mine straight away with your instructions thank you
This message was authored by: Lutta
This worked for me.
Thanks!
This message was authored by: StanTheMan73
I've had problems since update, with mute not working unless I cover IR end of remote, and occasionally when I press volume up, it keeps increasing on its own.
I have soundbar setup thro ARC.
had SkyQ + 2 Minis with Philips Ambilight 48"
Now SKY GLASS 65" +
3 Pucks
SONY S40R 5.1 surround sound bar
SKY VIP Diamond (20+ Years)
This message was authored by: 82bit
This solution (to Sky's created problem) seems only temporary? I've had to repeat this procedure for a third time already.
Sky Glass 65” [Gen 2] with Sky Live
Sky Glass 43” [Gen 1] with Sky Live
Sky Stream Puck x4
Sky Sports & Sky Movies + UHD & Dolby Atmos
Sky FTTP
Sky Mobile SIMO x6
Mines been fine since i fixed it, fingers crossed it stays that way. Do love the sky glass though
