Discussion topic: Sky Glass not working
This message was authored by: Ralph1
Message posted on 27 Feb 2025 06:31 PM
Sky glass freezing, not loading-tried resetting, keeps saying press home button but nothing happens, TV guide won't load.
Find out more
Message posted on 27 Feb 2025 06:51 PM
Re: Sky Glass not working
Might be worth connecting it to the internet via Ethernet cable if you are using WiFi and see if that helps ( this will help identify if the WiFi network is the cause). You will also need to disable the WiFi in the network settings of the puck.
