Discussion topic: Sky Glass - muffled sound
This message was authored by: KevM
The muffled sound issue appears to be a hardware problem with the Sky Glass panels.
This may prove to be a problem if you are out of the 2 year warranty. A repair or a new panel may need to be paid for out of your own pocket.
It would be useful to know if anyone has had to pay for a repair which worked.
This message was authored by: Jporch316
Re: Sky Glass - muffled sound
@KevM
Some of the earlier units had muffled sound issues . Seems to have been less of an issue the last 12 months as o haven't seen many posts
If anyone has muffled sound ... wouldn't they report it Sky and request a replacement during the warranty period🤔
Avatar for KevM
They should do.
Other chats reveal that people are using workarounds. Maybe because they're not aware it's a hardware issue.
Avatar for KevM
Muffled sound appeared on my unit just as the 2 year warranty expired.
Using workarounds is never a good idea within the warranty period🤔
Hopefully they are also reporting the issues to Sky?
Avatar for KevM
Hopefully.
Raising awareness should help with that.
This message was authored by: Tom0117
Mine wich is a month old is now muffled and sound horrendous I'm a new sky customer and this is so off putting
Avatar for KevM
Contact Sky. To be fair, they fixed my issue.
This message was authored by: Lala24
Like many I've read about, ours started the muffled sound only on certain channels just after the 2 year warranty expired, when it's a common issue surely the tv should be replaced.  I now need to pay for a new one. Considering moving away from Sky now, I was advised to get Sky glass by Sky due to signal issues and now this happens. Seems to be a money making scam.
Avatar for KevM
All I can suggest is to plead your case as best you can and to use the information here to your advantage.
This message was authored by: Pete2511
It's not a solution and far from ideal, but a work around would be to connect a sound bar or other similar periphial and change the settings so sound comes out of that.
This message was authored by: Jendayie
I had 2 replacements over 2 years ago and now out of warranty. The muffled, underwater sound is impossible. I now have to use bloodroots headphones too listen so only one person can watch! Just as well I live alone!
Does anyone know if a soundbar would resolve this problem?
This message was authored by: Nazz1
Im in the same situation I really don't know wa to do. Did u get urs fixed ? Any recommendations?
How plz ? I'm out of warranty n there asking for £624 to get it fixed
