Discussion topic: Sky Glass - muffled sound
Message posted on 11 Jan 2024 08:24 PM
The muffled sound issue appears to be a hardware problem with the Sky Glass panels.
This may prove to be a problem if you are out of the 2 year warranty. A repair or a new panel may need to be paid for out of your own pocket.
It would be useful to know if anyone has had to pay for a repair which worked.
Message posted on 12 Jan 2024 07:46 AM
Re: Sky Glass - muffled sound
Some of the earlier units had muffled sound issues . Seems to have been less of an issue the last 12 months as o haven't seen many posts
43inch Gen 1 and 55 inch Gen 2 Sky Glass & sky live camera 3 Pucks. Virgin media M350 hub 5x. Four sky mobile sims.
Message posted on 12 Jan 2024 10:14 AM
If anyone has muffled sound ... wouldn't they report it Sky and request a replacement during the warranty period🤔
Message posted on 12 Jan 2024 05:46 PM
They should do.
Other chats reveal that people are using workarounds. Maybe because they're not aware it's a hardware issue.
Message posted on 12 Jan 2024 05:48 PM
Muffled sound appeared on my unit just as the 2 year warranty expired.
Message posted on 13 Jan 2024 07:11 AM
Using workarounds is never a good idea within the warranty period🤔
Hopefully they are also reporting the issues to Sky?
Message posted on 13 Jan 2024 04:32 PM
Hopefully.
Raising awareness should help with that.
Message posted on 07 Apr 2024 09:01 PM
Mine wich is a month old is now muffled and sound horrendous I'm a new sky customer and this is so off putting
Message posted on 08 Apr 2024 07:35 AM
Contact Sky. To be fair, they fixed my issue.
Message posted on 08 Oct 2024 10:16 PM
Like many I've read about, ours started the muffled sound only on certain channels just after the 2 year warranty expired, when it's a common issue surely the tv should be replaced. I now need to pay for a new one. Considering moving away from Sky now, I was advised to get Sky glass by Sky due to signal issues and now this happens. Seems to be a money making scam.
Message posted on 08 Oct 2024 11:30 PM
All I can suggest is to plead your case as best you can and to use the information here to your advantage.
Message posted on 09 Oct 2024 07:54 AM
It's not a solution and far from ideal, but a work around would be to connect a sound bar or other similar periphial and change the settings so sound comes out of that.
Message posted on 30 Nov 2024 08:10 AM
I had 2 replacements over 2 years ago and now out of warranty. The muffled, underwater sound is impossible. I now have to use bloodroots headphones too listen so only one person can watch! Just as well I live alone!
Does anyone know if a soundbar would resolve this problem?
Message posted on 17 Jun 2025 06:18 PM
Im in the same situation I really don't know wa to do. Did u get urs fixed ? Any recommendations?
Message posted on 17 Jun 2025 06:19 PM
How plz ? I'm out of warranty n there asking for £624 to get it fixed
