19 Feb 2025 10:57 AM
It's a shame. I can live with 60fps but the stutter makes playing FPS awful. Didn't have the Gen1 but I'm loving the Gen2 on the whole as a TV.
19 Feb 2025 11:01 AM - last edited: 19 Feb 2025 11:01 AM
@JohnFourty @ Did you see the workaround? Not ideal but let's you game normally
Get the game on you want to play, then switch the TV plug off & back on, once it reboots go straight to the game on the sky menu & it'll run at 60 for you until you turn over or go to the Xbox dashboard as that sends it back to 55. It's a software bug, & fixable, no idea why it's taking so long.
Biggest issue is before they added ALLM, it worked fine without it, but now worry it off it's absolutely horrific & simply a no go.
19 Feb 2025 01:57 PM
I can confirm that the workaround, unplugging the TV after loading the game and plugging back in, does work.
Reported to Sky and made them aware that it is affecting Gen2 as well. They know about the issue and told me about the workaround that is in this post.
19 Feb 2025 02:18 PM
@JohnFourty thanks for ringing, the more the merrier. Crazy they tell you the workaround as a fix right lol, a workaround I discovered & this community worked out why & what was happening. It was implemented I think in June last year & is still happening.
The company who make the TVs are in Holland & they've been aware since at least October. Just disappointing tbh
20 Feb 2025 04:09 AM
Cannot believe it's still not fixed,Quick to take our money.
Typical company,Only concerned about profits......
20 Feb 2025 06:11 PM
Update. If you use the workaround to resolve the 5 sec frame skip, it is possible on the Gen 2 to play competitive games 😁
20 Feb 2025 06:18 PM
Destiny player 👍
