8
This discussion topic has been answered Discussion topic: Sky Glass delete series from playlist
This message was authored by: Topmansw
Is there a way to delete some series from the playlist? For example if you add a series linked program there may be multiple series. How can I delete series one, but leave series 2.
This message was authored by: Padam_Padam Answer
Re: Sky Glass delete series from playlist
You can't. It's all or nothing. The playlist is not a list of 'recordings' which the customer can delete, it's merely a list of all episodes which are available to stream.
@Topmansw  It's all or nothing unfortunately.
Isn't the case with other streaming services?
You have list of seasons which the gives a list of episodes in the season😉
@Exiled-in-HH Exactly the same as Sky does, but in answer to the OP there is no way to delete specific series.  If you add something to the playlist it will show all the series that are available to stream.
I know what the OP is getting at and it would be a nice feature but is unlikely to ever happen (it may not even be possible).
The big difference is that you can't record what is available via streaming, potentially all seasons all episodes.
if you try to do the equivalent with recording .... the HDD is soon full🤔
What needs to be improved on most services is a record of last episode watched, there no need for a record of every episode watched, and a way to discontinue watching a series😉
Surely that is just removing it from your playlist as Sky calls it, or the watchlist as other streaming apps call it.
Some apps do allow you to remove a show from the continue watching rail inside that service. Unfortunately not all of them.
This message was authored by: Fitchy
Yes you can ,you go to the playlist select the series that you wanted delete and press the tick button all done
Hi @Fitchy  and welcome to the forum.  What you are suggesting will unfortunately remove all the series of a programme not just specific ones.
Purely as an example Vera has a new series starting on 1st January (series 14).  If you add this to your playlist it will list all the series of Vera that are available on the streaming platform.  If you then try to delete the series you have already watched it unfortunately removes all series of Vera from from your playlist 😫
