This discussion topic has been answered Discussion topic: Sky Glass as a monitor for Gaming PC - "No Signal"
Message posted on 06 Oct 2024 01:01 PM
Hi all,
I have a brand new gaming pc (with dedicated graphics card), to connect to my Sky Glass TV using HDMI.
The TV recognises that something is plugged in but it says 'no signal detected'. I tried:
• 3 different HDMI cables
• all the HDMI ports
• switching the ends of the HDMI cable round
• changed HDMI-3 to 'Older Device Compatibilty' (though everything is brand new)
• power cycled both devices
I have no alternative monitor, the only other thing I have is a macbook pro.
Anyone set up a gaming PC with Sky Glass before, and been through something similar? TIA
PC specs: XUM Titan Gaming PC: AMD Ryzen 5 5500, GTX 1050 Ti 4GB, 16GB DDR4 RAM, 512GB NVME SSD, 1TB HDD, 500W PSU, aRGB, WiFi, Windows 11
Message posted on 06 Oct 2024 01:18 PM
NEVER MIND
It's my first gaming pc. Didn't realise the HDMI has to go directly into the GPU. Duh.
NEVER MIND
Message posted on 20 Apr 2025 03:06 PM
Re: Sky Glass as a monitor for Gaming PC - "No Signal"
Hi I'm having the same problem. Can you please go through what you did step by step thanks.
Message posted on 20 Apr 2025 08:42 PM
Hi, the gaming pc has 2 sets of HDMI ports. One of them goes directly into the graphics card. The HDMI needs to be plugged into that one, so I just moved to the other port and it worked instantly. Hope that helps!
Message posted on 20 Apr 2025 09:09 PM
Thanks Hudson123, now I should be able to play my retro games!
