Discussion topic: Sky Glass and use of it in 2nd holiday home
Message posted on 13 Feb 2024 10:38 AM
I am moving house soon. I was thinking of moving to Sky glass but I also have a holiday home where I would currently take my main box and use whilst there. If I move to Glass is this an option using a Puck? Should I stay with Q or do I need a second subscription but I don't want another bill as I am only there for a short number of weeks each year. It is only me that uses the Sky when at caravan or at home. Any advice greatfully received.
Message posted on 13 Feb 2024 10:45 AM - last edited: 13 Feb 2024 10:46 AM
Re: Sky Glass and use of it in 2nd holiday home
From the Glass/Stream T&Cs:
If you or any other person uses any of the TV services on Sky Glass or Sky Stream puck anywhere other than your home address you will be in breach of this contract and we may charge you an Additional Location Charge or suspend certain subscription services for use at that other address in accordance with clause 4.16 below. We use data received from compatible devices and network connections you use to access your TV Services to ensure you are only using your TV Services at your address and in accordance with clause 4.4 below.
4.4. You agree to use your TV services for your household's own private domestic enjoyment at your address only and not for any commercial or business purpose.
4.16. If you or any other person uses any of the TV services or your account anywhere other than your address, you will be in breach of this contract. As such, we may either suspend your TV services or charge you an Additional Location Charge for use at that other address based on the price of your subscription at your address. We will notify you before taking any action or applying that additional charge to your account.
Message posted on 13 Feb 2024 10:47 AM - last edited: 13 Feb 2024 10:48 AM
Note that's a breach of Sky satellite television T&Cs
Message posted on 13 Feb 2024 01:57 PM
Hi @Biscuit3
Additionally to what the others have posted, sky use active measures to check where Glass/Stream devices are being used.
They may impose additional charges or restrictions if detected. You could always consider using Sky Go while in your holiday home as this is permitted use.
MikeAlanR
55" Gen 2 Sky Glass atlantic blue, 65” Sky Glass ocean blue, Sky Live, 4 streaming pucks and EE FTTP Busiest Home (circa 1.6 Gbps download). Sky SoundBox. Former Sky Q, Sky+ HD and Sky+ customer.
