Discussion topic: Sky Glass & Sky Stream Playlist issues 01/02/2024
Message posted on 01 Feb 2024 07:25 PM
Re: Sky Glass & Sky Stream Playlist issues 01/02/2024
My playlist has gone, I'm happy in one way as I had programs which I couldn't delete
Message posted on 01 Feb 2024 07:26 PM
My playlist is back!!!!! 😁
Message posted on 01 Feb 2024 07:29 PM
Mine is alive too!
Sky stream #2 - Sony OLED
Message posted on 01 Feb 2024 07:33 PM
Sky Glass Playlist Not Working
My Sky Glass Playlist has disappeared, along with my wife's and another playlist. When I try and add a programme to my playlist it confirms its done it, but it doesn't show on my playlist. I've tried turning the TV off at the mains, but so far no luck. Very frustrating - any help please
Message posted on 01 Feb 2024 07:36 PM
Re: Sky Glass Playlist Not Working
Your post has been merged into this joint Glass/Stream thread on this issue. Sky are aware of the problem. Some customers are stating it's working again for them.,
Message posted on 01 Feb 2024 07:38 PM
@Wobdot wrote:My playlist has gone, I'm happy in one way as I had programs which I couldn't delete
@Wobdot This is just a glitch which will be resolved soon. When the Playlist returns it will come back with all the programmes that were originally on it. I have never had a problem with removing things from my playlist. If they don't delete in the usual way then go to Manage All and delete from there.
If you are meaning you can't delete from the Continue Watching rail then that is a completely different and frustrating experience.
Playlist is empty,
Our playlists have emptied, even new programmes added over the last couple of days. They are showing in the manage section, but are not available to watch. They were all in the playlists yesterday. Any suggestions other than adding them all again?
Message posted on 01 Feb 2024 07:40 PM
Re: Sky Stream Continue Watching
Thank you
Message posted on 01 Feb 2024 07:46 PM
My playlist and continue watching rails have now returned.
Message posted on 01 Feb 2024 07:48 PM - last edited: 01 Feb 2024 07:48 PM
All
Customers should start to see their playlists returning, if yours hasn't you don't need to take any action, please be patient and it will return on it's own.
Message posted on 01 Feb 2024 07:51 PM
Mine now all working - clearly sky issue
Message posted on 01 Feb 2024 07:56 PM
If you go into settings then click on update apps it resolves the issue.
@Fothergill1 thank you! I've had a programme I've not been able to remove in a playlist for months! I never knew you could remove stubborn ones using "manage all"
Message posted on 01 Feb 2024 07:58 PM
My playlist now restored.
Message posted on 01 Feb 2024 08:39 PM
Yeh all back 👍😃
