Discussion topic: Sky Glass air 65’’ wall mount holes
This message was authored by: Howd87
Are the wall mount holes for the air and the 1st gen the same distances or would I have to drill new holes? I've used the JML grip it so would rather not patch and re-drill
Re: Sky Glass air 65’’ wall mount holes
@Howd87 As far as I know they are the same.
Is Air going to be your main TV? I think it's strange not to go for the Gen Two given it has seven speakers compared to the two in the Air if so.
Avatar for Howd87
I have the 1st gen currently, looking at the 2nd gen.
@Howd87 Make sure you order the right one then! The Glass Air and Glass Gen Two are different beasts - don't be seduced by the cheaper price of the Glass Air!
